230 mopar head taped , gasket
ericp351
66
erie Pa
Hi all. Changing gaskets and noticed my no. 6 cylinder (area on head) was tapped clean thru to combustion chamber and tapped off (top) with a pipe plug. Thought little of it, till checked my "parts head" and noticed same. Was this a tap for compressed air or something? Also- I know modern books say do not reuse copper clad asbestos head gaskets. Also know reuse was done before in the millions of tractors and cars built with these gaskets. Anybody have first hand experiance with reuse success/ failure/ sealers (I like brush on non harding stuff) etc.??? Thanks!
Roller
51
North Lake, WI
That plug is directly over the piston, it is used to verify top dead center. Number 6 and number one reach tdc at the same time. If you put a rod in the hole and use a dial indicater to measure the highest point the timing mark on the crankshaft pulley should be at top dead center.
Frank
