800 series front springs
ucfjeeper
St. Cloud, Fl
Please do not misconstrue this as a classified post, you will see why in a second.
I have a set of 800 series front springs out of a 5 ton. Are these a wanted item like the front 2.5 ton springs for bobbing? I tried searching but didn't find anything. Anyway, is there a use for them, or should I scrap them? Thanks
73m819
314
gainesville, ga.
If you scrap, I SURE could use a spring purch ( the part that goes on top of the axle and under the spring)
ucfjeeper
St. Cloud, Fl
I have all the suspension parts. U bolts, springs, top and bottom plates. I bought a bunch of axles and one of the fronts still had the front springs on them. I knew the 2.5 ton guys used them for bobbing so I wondered if the 5 ton guys do. Thanks for all the replies and pms.
jimk
45
Syracuse, New York
I'd rather not start a thread and this looked like as good a place as any to ask.
<y 72' M813A1 w/w front spring profile is flat and I have about 1" between it and snubber(s). Rides OK. Is this normal of should there be more arch? Thanks.
MyothersanM1
19K M1 Armor Crewman
410
68
Culver City, CA
Front springs have no arch. Mine is the same...nice and flat.
