936 hydraulic speed
colesmotorsports
33
ND
Got a weird one,ive got one wreck ive had for awhile.
Always hated how slow the hydraulic speed was ,everything slow. kick the pto in rpms go to 1500,put transmission in 1-5 its just slow. Got another wrecker 936 kick the pto in throttle doesn't automaticaly put transmission in 1-5 raise throttle rpm to 1500, all the back crane stuff is 3 times faster . Seems way to fast,put throttle back to idle and transmission in to 1-1 doesnt seen to slow it down. why is the one so slow and other crazy fast that cant seem to slow it down.
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
Flow. One pump is obviously weaker than the other. GPM = speed
Transmission has to run at 1500rpms or more or it will burn it up when a load is put on it.
colesmotorsports
33
ND
Don't know it's really a big difference but dang cool, probably a pump or something???? I ve changed hydraulic oil, new filter. Need to put pressure gauge on it. The pump drive shaft spins way faster on the faster one . Think I red the transmission should shift through the gears up and down with shifter , not sure though.
