- 3,213
- 381
- 83
- Tonopah, AZ
I have read some threads about using a Battery Tender on the batteries, but would it be better two use two 12v tenders or one 24v tender?
Thanks!
Thanks!
AZ:
The battery tender brand makes a model with two separate 12 volt chargers in a single housing. I used one with my deuce that was stored all winter. The truck started right up this spring. I unhooked the battery cables and the dog bone before connecting the chargers. It only took a couple minutes to connect it all back together.
There is no benefit to rotating the batteries; top to bottom, right to left, etc.Yes rotating batts is the right thing to do also, Yes pulling batts and cleaning and rotating them will help one get the longest life out of them, so, I like i said, if the charger is a 24 volt they should be taken out and cleaned and charged individually to a full charge then rotated and put back in, if they have individual 12 volt chargers they should still be cleaned and rotated as said above.
