Benz 1017
925A1
PA.
I have a 1978 Daimler Benz 1017, that is in very good condition. I do have an issue with the 5 speed manual transmission and have not been able to locate a manual. If someone has a lead, please reply. Or if you can tell me if the idler gear needs to be removed to allow the counter shaft to drop for main shaft removal. This transmission may be in early 80's Unimogs as well. Thank you for any information.
Mark Musser.
925A1
PA.
I looked for hours online for any info on the DB - 3032 5 speed transmission, used on 1017 and 1017A military 7.5 tonne trucks. No luck at all. I did however disassemble the main shaft after trying every method use on past transmission tear downs. If anyone should have need of the details on the Daimler AG 5 speed military truck transmission, send a PM.
