Bolt pattern on A1 / A2 900 series 5 ton?
wilco
newross, in
What is the Bolt pattern on A1 / A2 900 series 5 ton?
same as the older 5 tons or bigger? 13.67 X 10 bolt ( 335mm X 10 bolt).?
Am looking for some 13.67 X 10 bolt ( 335mm X 10 bolt) 20" rims
Any US trucks use this pattern?
I guess this is the standard European heavy truck bolt pattern.
Tornadogt
Adkins, Texas
10 x 11.25 for M939series.. MRAPS and Hemmits have a larger pattern... Check with "PeeShooter" He makes adapters plates for different wheels and is very knowledgeable about patterns / back spacing and what may work for you...
