Brake pedal is spongy but still works well
als804
66
kimcheon, ROK
My brake pedal got suddenly weird. When i drove trails I pushed the brake pedal many times and then clearly noticed i got spongy pedal. It’s very very sudden and scary. But the brake still works……
but there is no resistance until reaching to 3/4 travel of The pedal. there is no any fluid leak in car and master cylinder reservoir still has full of fluids. But No brake pedal pressure but i can feel pressure at almost last point where Brake starts to work. And i tested the brake that i was putting both brake pedal and gas pedal together then car didn’t go. I can’t push the brake pedal to floor due to pressure And i noticed there is still brake power at the last point.
is this master cylinder failure? Power steering works nice
adf5565
647
Tioga, PA
I’m not sure this would happen suddenly but I had a similar issue after replacing my brake system. Turned out it needed to be bled more as there was still a pocket of air in the system and also my rear shoes needed to be adjusted closer to the drums. It’s worth checking while you’re troubleshooting.
als804
66
kimcheon, ROK
the next day i tested my brake and worked it again. one day resting could make brake fixed ?
i guess internal seals problem in the master cylinder. so i decided to replace it with brand new master cylinder which i already has.
changing it is very easy jobs. i followed the bleeding procedure in TM. also i found input rod of master cylinder was very rusty and dirty. so i cleaned it with wd 40 and sprayed Sillicon oil. i used DOT 4 Brake oil instead of DOT 5 wich you can see it with very rusties in the master cylinder below picture.
( Choosing breake fluid is always battlefield. In Korea is very humid so i will regulary change DOT 4 which can abosrber water much more than DOT 5. )
Right after chaning it i can feel very soft and strong pressure of brake. i love it,
the old master cylineder which i suspected internal leakage.
