Can Anyone ID These Rims?
Gottlos
Former 95B Ft Sam Houston
Canyon Country, CA.
I hope the image gets a little bigger? Can anyone identify these rims from the picture? They look as to be six lug rims for a deuce, but I haven't seen the rims with the tires dismounted all that often so I'm unsure.
74565339_gl_tiny_thumb.jpg 74565308_gl_tiny_thumb.jpg 74565300_gl_tiny_thumb.jpg
Gottlos
Canyon Country, CA.
If they are deuce rims I'd like to acquire them and clean them up/paint them. Then rotate them into use on my m109. That way I can get the whole truck done in two tries.
tommys2patrick
203
Livermore, Colorado
20" by 7.5" deuce rims without the lock ring. However, if you happen to have some extra 5 ton truck rims of the 20" 10 lug bud wheels flavor, the lock rings will fit them. There has been some variation in the size/design of the lightening holes over the years. If you look closely at the rims you will see the size info stamped into the rim as well. Some of the older rims were riveted together rather than welded as they are today.
Welder1
156
Albany Ga
Those look to be the late model deuce rims. I bought a set and the only issue is the oval openings in them are much smaller than the original. This makes it much harder to access the inner valve stems on duals.
