coolant expansion tank
motorman
Loganville GA
hello gents,
speedt the weekend cleaning up some loose ends on my M1009.
one thing i have traced but not fixed is a coolant leak.
i have discovered that the expansion tank has a small leak on the bottom seam where the 2 pieces of injection mould come togeter.
does anyone have an idea for a fix?
can i just glue it? melt it?
any advise is appreciated.
best regards
m
blzrgb
mississippi
I used a green stick of plastic, melted with my torch. A lot of guys use them to plug holes on flat bottom boats.
I got mine from the local Car Quest.
Warthog
228
OKC, OK
Zip ties work also to weld the crack back together with an soldering iron.
jj
17
Kutztown,PA
That expansion tank was still available at the dealer three years ago, or so. About $25 retail, as i recall. The part number should still be molded into your tank, mine was. The last four digits were all twos, sorry i can't remember the whole number right now. I've been awake for about thirty hours, and i am about to get real crabby. Post back here if you can't find the number on your tank, and i'll skin the number off of mine for you.
Warthog
228
OKC, OK
. The last four digits were all twos, sorry i can't remember the whole number right now. .....Post back here if you can't find the number on your tank, and i'll skin the number off of mine for you.
I posted the number in Post #3
GM number - 14052221
NAPA number - BK6053401
jj
17
Kutztown,PA
Yes you did. And i completely missed it. My apologies. It looks like my eyes are getting as bad as my memory: there were THREE twos. I'm gonna chalk it up to "PWE". That is, Posting While Exhausted.
