5tondeuce
- 6
- 18
- Hampton/New Brunswick/Canada
Hi All,
Well I require your wisdom and experience once again. I am in the process of replacing a leaking seal on the accessory drive pulley on my M818 with the cummins engine. I am not sure of the best way to ge the nut off the pulley without it turning. In hind sight I should have left all of the belts on it.
My question is it O.K. to use an air gun to remove the nut or could this do damage to the injector pump or air compressor? Or should I try to find a way of keeping the pulley from turning and take the nut off using hand tools?
Thank you in advance and I am looking forward to your feedback.
