friday the 13th
xenocath
searching.............
193
Glen allen, VA
yesterday morning pulling into work i suddenly heard three distinct pops coming from under the truck and steering went away. i stopped to crawl around underneath and find three of the 5 inch 1/2 20 studs holding the steering lift block thing snapped off inside my steering knuckle. i then proceeded to learn two things: one you should not install a block under your steering arm they are a real bad idea and two if you are going to try and drill out the studs remove the steering knuckle and take it to a machinist, attempting to" just drill them out real quick and stick some bolts in" may seem like a good idea but let me tell you it is not. so now hours of drilling and busting easy outs means i am seeking another steering knuckle figure 101 part 19 in the intermediate parts manual if anyone has a line on a good source please let me know i am not having any luck these things are almost impossible to find from all the usual sources. talk about luck if this had happened any earlier then when it did..................
Cucvnut
61
Carver, Oregon
I would go with cross over man ! lift blocks are scary for steering. reid makes replace ment steering knuckles. dana 60 stuff is $$ sorry bout your bad day
