Banshee365
- 14
- 0
- Ocala, FL
Ted's Trucks-N-Stuff in AL. I think the newer ones are thicker.
-Kelly
-Kelly
I believe it's a step that started with the older front axle shafts. The old style shaft doesn't use a U-joint. It has a CV type joint. This joint must have that bath of grease to keep it operating.55Cameo said:Why pack the knuckle with 2# of grease? ...in the military we didn't pack them full like that.
No. You can install the zipper type of boot without tearing everything apart. However, it's a good idea to take it all apart to inspect everything. You must take it all down if you wish to install one piece boots.SpruceDeuce said:quick question do i have to take everything apart like that if i just want to change the boots??
If you use the one-piece boots----yes.quick question do i have to take everything apart like that if i just want to change the boots??
