How can I stop melting terminals?
russojap
Knoxville TN
This is the second time this has happened, the first time I melted the post off of a battery. I was certain they were tight, but maybe because the batteries aren't secured down it's causing the bolts to loosen up. Do I need lock washers? Why did they melt in the middle?
IMG_20190129_145831013.jpgIMG_20190129_145720357.jpgIMG_20190129_145648187.jpgIMG_20190129_145654226.jpg
Scar59
41
Mt. Eden, KY
Something was loose. I've had that happen. The cable bolts need to be tight. They get over looked sometimes. Securing the batteries is a must, lots of bumps and vibration adds to the issue.
frank8003
4,980
Ft. Lauderdale, Florida
Never ever never run batteries in any vehicle that are not secured down.
'Tiss a quick way to lose money on any liquid filled battery.
.......and show me a cheap method as to how how to secure battery for the General.
IMG_1648.jpgbattery box.jpgIMG_1650.jpgIMG_1653.jpgIMG_1654.jpgIMG_1661.jpgIMG_2221.jpgIMG_2223.jpg
Melting the post off a battery/batteries requires high amps
which is detrimental to vehicles and humans.
Big Tom
114
Millington md
Clean everything good as said ,but also put some dielectric grease between all parts , on electric circuit the biggest cause of heat is a bad connection, loose or dirty will do the same
Big Tom
18operator
1,848
Seville, Ohio
Scar59 Hit the target. If those terminals aren't tight then something is bound to arc. I've had it happen to me. And make sure the batteries are in there snug.
1,168
Check you positive cable where it goes through the hole in the frame. Be sure it has not rubbed through.
Secure your batteries. If they move the cables and clamps can loosen.
sandcobra164
287
Leesburg, GA
I once melted a battery terminal and the culprit was not what I would have expected. It was actually caused by a weak battery in my 2 battery set-up. Member 74M35A2 explained it to me in a very simple for me to understand manner. With healthy batteries (12.8 Open Circuit Voltage), much less amperage draw is seen on the electrical components from the batteries to the starter. The weaker the batteries OCV, the amperage goes up somewhat exponentially during starting. I wish I could find the thread where he pointed that out to me as he explained it better. In addition to ensuring batteries are secured properly and cables are clean and tight, make sure they are charged fully.
Jbulach
2,109
Sunman Indiana
Too many amps...
The bolt and the lug on the end of the cable is so crusty, it’s making better contact on the bolt which is arcing on the interior of the hole through the lead, melting from the inside out.
russojap
Knoxville TN
Thanks for all the suggestions, definitely like the idea of the grease. The bolts on two of the terminals were in fact loose, I guess driving the truck around the bumpy yard and the engine idling caused them to loosen up.
russojap
Knoxville TN
Too many amps...
Could I put that conducting grease inside the bolt holes to prevent this from happening again?
Jbulach
2,109
Sunman Indiana
It wouldn’t hurt, but that lug needs to be sanded bright on both sides, new bolt, stainless nuts, and bolts are really nice, as well as brass terminals.
1,168
Local battery or truck shops or google "military battery terminals".
1,168
Food for thought, when the alternator looses battery connection it will go to full output.
That will assist with the damage to the terminals. It will also kill your voltage regulator.
cucvmule
collector of stuff
1,151
586
Crystal City Mo
I like using NAPA chem washers and their protective spray, red color just like frank8003 used on his terminals. If you look at his pictures you can see the red stain
from the spray that helps with corrosion and ark track, dirt on the surface of the battery that drains the positive terminal towards the closest ground.
As said before, clean, dry, tight. The melting point on the lead clamp is where it made some minimal contact creating a lot of resistance for the current needed to start or maintain electric accessories.
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
military terminals are Grote # 85-9481 and 85-9480 for 5 each of the positive and negative. Available at napa. but I agree on switching to stud post batteries.
