RAYZER
- 58
- 48
- sanford/florida
I've been having an issue with the code E injection pump on my Ldt deuce tractor and would like to replace it with an Lds code B Pump i have on hand, will this work?
Searching through tm 9-2815-210-34, I find the Lds pump advance unit springs are shorter and have a lighter compression rate than the Ltd pump advance, if im not mistaken this would mean an earlier advance and torque curve with more power at lower (than Ldt pump) rpm, this would be an advantage for i frequently pull a 10k lb trailer, sometimes long distance.
Who has done this and with what results?
What ealse do I need to consider?
