M1009 glow plug problems
irishvin
Wappingers Falls, NY
Hey guys!
I'm trying to figure out why my glow plugs only get power after I start to crank the engine instead of before, like it should. I encountered this problem after my engine swap and just got around to fixing it (or trying to) and found that the starter relay was broken. I replaced it and it's still not working properly. I don't know what to do now. I tested the incoming line and the line coming out and the only time they come on is during a cranking.
Thanks in advance!
Warthog
227
OKC, OK
The TM 9-2320-289-20 tech manual has a step-by-step procedure to test the system.
Warthog
227
OKC, OK
Be sure to read the GP Operation sticky. It helps explain how the system works. Has a great video.
