M1009 NP241 direct swap?
nudewheeler
Tucson, AZ
Howdy Folks -
Quick question that was generated while trying to troubleshoot driveline vibrations.
Is the NP241 a direct drop in swap for the NP208 in an M1009?
Any need for:
  • adapter plates
  • shifter linkages
  • crossmember modification
  • rubber mount modification
  • speedo cable modification
Is this literally a component swap with no other considerations?
May have the opportunity to pick one up locally with a SYE installed on it. More info to come. Doing homework/research first about the install.
To only major incompatibility appears to be the input shaft for most NP241s were 27 spline. JBconversions sells a 32 spline input shaft for the NP241 to mate with a TH400.
Thanks in advance.
nudewheeler
Tucson, AZ
CUCVnut -
Thanks for directing me to your build thread. Nice truck. I've really gotta think about axles at some point.
Hey, I saw you referenced changing Tcase mounts. I wasn't quite sure what you were saying. I have an outstanding order from ORD for their BG01006 mounts. Are these compatible with an NP241 swap?
What other anchor were you referring to?
Are you able to post a link to an online vendor where you purchased both the 2108 and 2107 mount/anchors you referenced?
nudewheeler
Tucson, AZ
I found these parts on Orilley's auto parts. They look quite similar to the ORD poly t-case mounts. I am still curious what mounts (manufacturer or vendor) you used.
2107
2108
