M1009 Rear Differential Bolt
1,168
Should be in the -34PTM.
1,168
[h=2]5306-01-148-6765 Features[/h]
MRCParameterCharacteristics
AAJDThread Class2A
AAJFThread DirectionRight-hand
AASAThread Length0.800 inches minimum
AASBFastener Length0.930 inches minimum and 0.960 inches maximum
AASKHead StyleHexagon extended washer
AASUHead Height0.259 inches minimum and 0.289 inches maximum
AATBWidth Between Flats0.489 inches minimum and 0.500 inches maximum
AATCExtended Washer Diameter0.686 inches minimum and 0.706 inches maximum
AATDExtended Washer Thickness0.071 inches nominal
AAUMLocking FeatureLocking teeth bearing surface of head
AHYMNominal Thread Diameter0.312 inches
CMLPThread Quantity per Inch18
CQBCMinimum Tensile Strength125000 pounds per square inch
CQFMHardness Rating80.0 rockwell superficial 15-N minimum overall
MATTMaterialSteel comp 1021 overall or steel comp 1022 overall
MDCLMaterial Document and ClassificationSae assn std all material responses overall
THSDThread Series DesignatorUNC
[h=2]5306-01-148-6765 Manufacturing Part Numbers (SKUs)[/h]
MFG SKUCAGESTATUSISCRNVCRNCCSADCDACHCCRNAAC
1000893611862H5955AZ
100089367X677A5235AZ
38495111862H595AKZ
3849517X677A595AKZ
[h=2]5306-01-148-6765 Manufacturer[/h]
MFG SKUCAGEManufacturerTypeStatusRole
1000893611862General Motors Corp.AH
38495111862General Motors Corp.AH
100089367X677General Motors LLCAA
3849517X677General Motors LLCAA
