M105 Tongue length
194
Norfolk, VA
I'm looking for the tongue length of a M105 a1 or a2. Apparently it wasn't considered a critical dimension in the TM. So if someone has a 105 and tape measure I would appreciate if I could get the measurement from the tip of the lunette ring to the front of the box. Thanks.
DieselBob
13
Arnold Maryland
Well there is a vertical reinforcement channel in the center of the front wall of the box so here are the 2 measurements. From the brace on the front of the wall you have 51 3/4” From the front wall it's self it's 53 1/4”.
1,168
The box is 9' long. give or take a few ...
1,168
Actually, depening on your math skills, the information needed is in the TM.
Dimensions (inside):
Height:
To Top of Side Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1 ft 6 in. (46 cm)
To Top of Stake Racks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 ft 9 in. (114 cm)
To Underside of Roof Bows . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 ft (152 cm)
Length:
Body . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . . . 9 ft 2 in. (279 cm)
Stake Rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .. . . . . . . . . . . 9 ft 3 in. (282 cm)
Width:
Body . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 ft 2 in. (188 cm)
Stake Rack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 ft 1 in. (185 cm)
Dimensions (overall):
Height, Less Paulin (empty) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 ft 2 in. (249 cm)
Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 ft 9 1/2 in. (420 cm)
Width . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 ft 11 in. (211 cm)
Drawbar Ring (adjustable) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 1/4 in. or 34 1/2 in.
(77 cm or 87 cm)
1-9
Norfolk, VA
Yeah the box length and overall length are in the TM, but the Tongue length doesn't equal Box minus overall. At least not to the accuracy I was looking for.
Thanks again guys
Wow that was fast DH it took me about an hour to find that page earlier. Now I need to buy a 105 to find the missing 3.75" :-D
swbradley1
Modertator
1,573
Dayton, OH
This was your basic math problem.
I was going to answer but I wanted to know if anyone else would see that.
