M715 Owners Near Wisconsin
VenomInjected
WI
Well... long story short... an update of where were at....
Day I got it:
Broken all the way down and powdercoated
During Rebuild and Cummins Install
After Axle Swap
And Current Status
dozenjeeps
forestville, wisconsin
Hey, truck looks great...…..garage looks different if I remember correctly, as I bought your axles and engine when you started the project...….still run mine a lot but as of now did not need any of the spare parts I bought.....that's a good thing!!! super job and wish I could have one like yours!!!
VenomInjected
WI
Yea... Moved into the country south of green bay (with a bigger garage :D ) as well as had a child so between those to life events the Jeep has been on bit of a back burner but were finally turning some wrenches again.
dozenjeeps
Great to hear, glad for you, especially having the little one as you will enjoy the child even more than the truck!!! good luck to you and great to hear you moved out of town, you seemed more like a country guy to me!!!!
VenomInjected
WI
Well... still chipping away.... Just about to start wiring.
Cummins 5.9L 12 Valve VE
Ford ZF5 5 Speed Manual
Ford Married NP205
Ford Dana 60 Kingpin Front Axle
Ford Sterling 10.25 Rear axle
4 Wheel Disc Brakes
Hydroboosted (out of a 2010 Duramax)
Power Steering Added
Brandon130
West Bend, Wisconsin
When you installed the engine, how did you know where to place the mounts? I was going to place the engine based on how it sat with regard to the cab. It looks as though you knew exactly where to install the engine mounts, then put the cab in place and...no clearance issues?
I hope that’s the case and you’re willing to share how you did that! If not, what problems did you run into?
