M882 no parking lights
44CCKW
Port Republic NJ
After a lot of wire tracing,I found that 2 wires in the junction block on the fire wall had been placed out of order.By this I mean the brown wire for the parking lights was in the wrong plug in the junction block.It appears to have been made like this as the wire harness was never molested.I just got this truck and I'm going thru it to fix all of the things that need attention.This is the first time I've seen this type of issue.You would normally think bad switch or relay.Not a misplaced wire.Everything works fine now.
