m917 won't shut down.
Abrant23
186
Charleston, SC
I've done a bit of searching on this subject, but have come up empty.
Our 917 sporadically wont shut down when the key is switched to the off position. Anyone had this happen before? It doesn't do it all the time, but every now and then it will continue to run after the key is turned off. If I take and short the end of the bolt on the fuel shut off solenoid to anything metal on the engine, it will shut off.
Curious as to where I might find the troubleshooting for this in the TM or if anyone has a quick solution for this issue?
Thanks!
Abrant23
186
Charleston, SC
Next time it hangs up, reach under the dash and pull the connector off the ignition switch, if it kills the engine you need a new switch!
It’s definitely something in the switch. It did it again this morning and jiggling the wires on the back of the switch shut it down immediately. Gonna clean em all up and see if that helps.
Thank you!!
