M988 glow plug Wait light issue
EnteJager
NJ
Searched and read accordingly.
Wait light and glow plugs previously worked fine, then nothing.
Rotating switch to glow plug position "wait light" illuminates for a split second. No power to glow plugs (mulimetered)
Disconnected batteries prior to all wok accomplished.
Installed brand new batteries
Ohm'd all glow plugs(okay) then replaced all with new ones.
Replaced PCB (was green with green sticker) with a brand NOS PCB (silver sticker) and GPC matched set in box.
Installed Kascar ground harness (cleaned all ground points accordingly)
Cleaned all plugs and dielectric grease connectors. GPC plug and both connectors of PCB.
Am I missing anything? before I drop the cash on a new eess from kasar. Anyone know where I can get one cheaper?
Dave
EnteJager
NJ
Dropped the cash on a new eess smart start and now everything works as advertised. With everything I went thru its a well checked out system.LOL
EnteJager
NJ
Couldn't find much else out there. Picked up a new in the box black silver label, no go. Just happy to be able to drive on cold days again.
Retiredwarhorses
3,936
Brentwood, Calif
black box silver label is not an EESS, it's a PCB protective control box that requires a glow plug controller in the water crossover...not the same as an EESS S3 and TSU.
the standard for all trucks is EESS...be it S3 or yellow label EESS with TSU by Nartron or KDS.
EnteJager
NJ
Yes, I know the difference between a PCB and EESS. #1 and #2 explain that I bought a new EESS from a vendor and now everything works as advertised. I bought a Black silver label PCB that was supposedly new in the box and it did not work. That is why I dropped the cash on the EESS. After going thru the whole system.
EnteJager
NJ
oh...ok, I will remind myself not to respond to your posts.
Really....? I was just letting you know your post was misguided. I try to read all the threads before I post up and try to school someone.:mrgreen:
Feel free to comment, I don't get mad or take it personal.
