tony1224
- 3
- 3
- live oak,florida
I have a problem trying to start my MEP-004.It was starting pretty good at first .it was running and stop running.I was checking every thing and if i had any power.I got my meter and find out that when the starting is off I am getting 24 on the switch.as soon as i move the switch to run the volts drop from 24v to about 9volts.also the oil light on the panel is very low.I went ahead and put the 2 wire on the back of the amp charging gauge and that way it does start and state running.but once you do that the gauge don't read if it is charging or not because I only have power to one leg of the gauge.It is not the gauge because I do have also a MEP-005 that it is running fine so I test the gauge on it and the gauge is find.I also switch the whole control box and I still have the same problem so I know that is not the gauge or control box.Need help guy's.any suggestion????
