New clutch install help.M813
zxmedic
Canada
So I am just in the middle of new transmission and clutch install on my M813 my truck seems to have had a aftermarket pressure plate installed . Ive had the flywheel resurfaced i went to install the new pressure plate and friction disc and there is barely any grip. Using the information in the pics and checking the new pressure plate there nearly a 1/4" height difference between the 2. Does anyone have a flywheel out and could measure the surface to bolt lip for the pressure plate. So i can compare. thanks
Sent from my LG-H812 using Tapatalk
MyothersanM1
19K M1 Armor Crewman
410
68
Culver City, CA
Did you remove the three shipping bolts and washers on the new pressure plate? My pressure plate is different than that of the one in the TM. It came with instructions to remove those bolts.
Here's my flywheel after machining over five years ago for reference. Sorry, but I can't give you measurements.
zxmedic
Canada
Thanks for the reply it was my own failure. Being the 2 pressure plates are so differemt .I did remove the bolts after installing the new pressure plates. Now my issue is the Transmission only seems to operate in reverse the shifter goes into 1 2 3 4 5 detent and only partially into reverse. If i let the clutch out the truck backs up with the stick in neutral. Is it possible the tower was installed with the shift forks outside the shift grooves and this keeping it in reverse .?
zxmedic
Canada
So install is complete in the end the reverse issue was that the Transmission shift fork was out of the collar locking it in reverse. Good i didnt try to drive it.
