bigelk50
- 13
- 0
- albany, Or
Ok guys I am stumped. It is probably some thing small I am missing but I need your help. About a month ago my M818's starter stuck in the crank position. Luckily I did not have a total melt down by the time I got the + battery cable off.
Today I pulled the starter and then took apart the solenoid and the contacts were burnt pretty bad. I cleaned them up and the disc that pushes against them. Put it back to gather and reinstalled. Hooked everything up the way it came off and hit the switch. All that I get is a click in the solenoid. The batteries are at full charge, but I do not have a load tester. I checked and tested my switches, no problems there. I am out of ideas, other than taking the starter to the shop to be looked at.
Any ideas?? TIA
Any ideas?? TIA
