- 2,135
- 612
- 113
- Davis County, UT
Today the Deuce got it's first oil change (well, by me). It didn't look too bad; no other engine fluids in the oil as far as I can tell. So I'm pleased enough about that
(I'm not using the fancy spin on filters) On top of the oil filter there is a metal cup and spring. My question is, what is the proper orientation of this cup? Should the inner cup lip be pointing down into the center of the filter, or upward out of the filter? When I took the housing off both orientations were used. As far as I know, the last oil change was done when the Utah National Guard owned the truck. Does this function as a bypass?
I've went over the unit maintenance section about the oil filter change (TM 9-2320-361-20 page 3-12), and the cup used in the picture looks different than mine, but I *think* it's showing the inner cup lip DOWN into the filter. The "cup" is #8 in the attached picture.
Pictures worth 1000 words:
