CES 3245th
- 0
- 16
- Boston Ma
I thought I would take this opportunity to share a couple of upgrades that I did that you might find useful. I changed my oil a couple of days ago using this new device that I had installed from the last time of draining my oil. Using this EZ oil valve drain w/ 90° elbow worked awesome! I also installed a new oil filter set up. What I also did was to discard the (3) nuts on the underside of the truck frame. I installed (3) 3/8-16 Steel Rivet Nuts To remove the diamond plate and gain easier access to the oil filter for removal and installation. Please see attached pictures. I think some of you will find this very useful I know I did.
1984 M923A1 5 Ton W/NHC-250 Motor..... Picked up these parts from FleetPride EZ Oil Drain valve 25MM-1.5 part # 6802 EZ5 $33.57 / L-Shaped Hose Nipple 5/8" ID part # 6802 EZ-L002 $10.75
In my opinion this was an excellent upgrade and well worth the money.
![1.jpg 1.jpg](https://www.steelsoldiers.com/data/attachments/501/501480-22aece853e55be566edca52bb4c50761.jpg)
![2.jpg 2.jpg](https://www.steelsoldiers.com/data/attachments/501/501481-fd23381ebb1c4acd0bf3e0cddf74f0ed.jpg)
![3.jpg 3.jpg](https://www.steelsoldiers.com/data/attachments/501/501482-5ce8cbe033c0b2023041c4474927cc8f.jpg)
![4.jpg 4.jpg](https://www.steelsoldiers.com/data/attachments/501/501483-cb09fb7f51b1f3238693b646786a7ee0.jpg)
![5.jpg 5.jpg](https://www.steelsoldiers.com/data/attachments/501/501484-fa3ce43a84f8dda2b51de884f9d082f4.jpg)
![7.jpg 7.jpg](https://www.steelsoldiers.com/data/attachments/501/501513-fb8354cca7aa30d2064e6b9add340a75.jpg)
![6.JPG 6.JPG](https://www.steelsoldiers.com/data/attachments/501/501485-5628aa08d909b41f342de6003c5a5206.jpg)
