Rockwell spider gears
RANDYDIRT
Furlow Ar.
I was under the impression that the rockwell axles were pretty much bullet proof, so needless to say I was upset when I twisted the spider gears out of mine the other day.
I have the third member pulled but don't have it apart yet, but I did find about a hand full of shrapnel (gear teeth and washer pieces) in the bottom of the axle housing. I do have a wanted add in the classifieds for a replacement set, so I have to ask. Will a used set fit right in, or do the washers come in different thicknesses to set some kind of backlash on the spider gears?
Dirt
gringeltaube
Staff Member
2,351
Montevideo/Uruguay
A few years ago barstow truck parts used to have a huge qty of NOS replacement kits (2520-752-1777), fairly cheap. Others might have them too, so better check out the typical suppliers before buying used.
The kit comes complete with 13 parts in total, including the washers which I think only come in one (std) thickness.
TM9-2320-361-34P shows them all as being parts of kit P/N 5702299 but the number on the box is the one stated above.
G.
m16ty
210
Dickson,TN
Find somebody that's parted a few trucks. I'm willing to bet they have a bunch of rear axles laying around (rockcrawlers only need two ;)). They can usually be had for $300 or less for the complete axle.
Accually, the Rockwell axles are fairly small for a truck the size of the deuce. They will break from time to time.
