Tire & Wheel Knowledge
simp5782
Feo, Fuerte y Formal
9,284
Mason, TN
Will any of the following fit safely on a 939 series truck? 16.00R20? 395/85R20 w/wheels? 365/85R20 w/wheels?
Hopefully these questions don't violate our rules.
Thanks,
Larry
The tires will all work just fine on any budd combat wheel that is 20x10". 1600R20s will rub in the front with standard combat wheels when turning. Some folks use HEMTT combat wheels to fix this. Some folks also raise the bed a few inches to prevent contact when offroad.
The wheels depend on what type they are. M939s require wheels with a double taper so on the rear axles the wheels are turned facing in. Some LMTV type combat wheels that are available are only tapered on one side.
frank8003
4,980
Ft. Lauderdale, Florida
"Will any of the following fit safely on a 939 series truck? 16.00R20? 395/85R20 w/wheels? 365/85R20 w/wheels? "
Search on/in SS with the search function and in google.
At 400 to 500 bucks each me thinks you need to search and search a lot.
Think of all the search strings you can and use them.
If you are really going to do business and buy wheels/tires then start a conversation with
Wes, simp5782
goofy me, as I was writing this WES had already replied to you. See what I mean?
