Deuce_Biganslow
- 0
- 6
- Evansville, IN
Ok, so I just bought a tow bar set to tow my M37 home when necessary until I get fixed what seems to be a sporadic issue that's been known to leave me stranded. I've also wanted a set for my M109's and M35, so I'm glad to have them.
Anyway, my first tow came two weekends ago - about 5 days after purchasing the tow bars (...glad I had them!) Anyway, I noticed that my M37 didn't track very well, and there were two times that I had to get out and adjust the steering wheel to keep from plowing on dry pavement...so I've been a little concerned. I did the tow with our Lincoln Navigator, and I really felt the M37 resisting me; I even had to steer the Navigator while going straight to counter-act the M37's affects. I looked at the tow bars, and I noticed that the two sides appear to be different - although I would have thought that everything should be standard (as far as lengths and hole locations and such) so that the parts could be used interchangeably, so I wouldn't think it should matter much.
![DSCN0094.jpg DSCN0094.jpg](https://www.steelsoldiers.com/data/attachments/80/80214-710190763568adc47ffa5aa92a7ac3a0.jpg)
Well, I attempted to tow it again yesterday because it allowed me to drive out to get my M109 from my cousin's place but get both vehicles back home, and it plowed badly again so I measured the two sides and see that they're different lengths - by a little less than 1". (The alignment on the M37 doesn't seem bad, so I don't think it's an alignment issue...although I could be wrong.)
![DSCN0100.jpg DSCN0100.jpg](https://www.steelsoldiers.com/data/attachments/80/80216-8677ad8ccef16079103df49ed1133806.jpg)
I don't want to drill new holes, but I'm thinking that I should probably have two new holes drilled that would produce a triangle with two legs that are exactly the same lengths.
The TM recommends keeping the tow bars adjusted as closely as possible to the retracted position, but I'm wondering if running them extended may reduce the problems I'm experiencing.
I am also wondering if I have the correct feet/adapters. I've been told that these are the correct adapters for the M37, but I had to use washers to take up some extra space; I do plan to relocate the washers on one side of the truck to the other side of the shackle mount in order to keep things as symmetric as possible, but this will not fix the different tow bar lengths.
About 10 months ago, I used this tow bar set to tow an M109 and did not notice any issues...so I don't know if it's just the M37 or what.
I would like to either find a matching side for my tow bar set or drill new holes to make sure that everything is the proper length...but I'm wondering if anyone has any advice for me in the mean time.
Thanks in advance for any thoughts or recommendations!
DB
![DSCN0098.jpg DSCN0098.jpg](https://www.steelsoldiers.com/data/attachments/80/80215-e582fd459d5560d475d60d5d2b3b08cd.jpg)
DB
