Turbo cross-over pipe?
remote6
Kenosha Wisconsin
For my M1009 I made one up but it was hitting the front drive shaft so I just had a muffler shop make one for me they went all the way around the transfer case and back up, works good cost 200$
richingalveston
120
galveston/Texas
I do not know of any. curious why you would need to do this. It will only make your front driveshaft angle worse.
ORD sells competition motor mounts they may add some clearance, supposedly they are a lot stiffer. They also have a high clearance cross member if it helps you any. I think I am going to have to add the High clearance cross member when I add the turbo so that I have room between the cross member and steering link for the cross over pipe.
1,169
Why start a new thread when you already have one going on this topic?
1,169
Merged with your other 2 threads.
southdave
ripley, oh/TDY Lordstown,Oh
Here is what happen to me... I bought a 1009 for 275 bucks off gl. It was missing the top end. I bought 6.2 out van.. me being stupid about the matter dropped the motor in, couldn't get the 400 mount up with cross member. It started the whole motor mount issue... the best way I have found to run cross over pipe is to hack away and make cross in front of the tranny mount.. give it adout 1 1/4 clearance. .
