Whats wrong with this u joint?
KsM715
142
St George Ks
Yep. no grease fitting= no grease in the joint. Or atleast doesnt look like it has had any put in it in awhile.
dependable
187
Tisbury, Massachusetts
The shiny lugs on u joint indicate some slop in the connection. When you replace the u joint, you should get new hardware (bolts & straps) These are available, just say you want u joint straps for a 84- 86 k-30. Some oem u joints had no grease fittings. If the truck is very high mileage, and has been run with bad u joints, one can add some strips of thin machinist shim stock to take up slack in axel side of yoke. See you are missing zerk , but above is all true.
OLDCHEV4X4
Glenmoore PA
I got it this way from GL. The rear uses external G shaped clips and the front axle ends use the internal C shaped clips. The army put both kinds of clips in and called it good.:???:
Mudstone
Norman OK
is this the same as for the blazer? if so can someone explain this to me. I fear i may have done something wrong on my truck.
