Why crawl if ya don't gotta.....
Dieselsmoke
CA/NV
Sure, there's plenty of room under the deuce to crawl around, but if ya don't have to and have access to a lift it sure makes things a lot nicer and cleaner too :)
[/img]
rmgill
14
Decatur, Ga
The deuce has enough room to crawl around under. Not quite enough room to work under. The 5 tons, they have enough room to work under, crawl under on your hands and knees practically, set up on your backside with room for head and shoulders under the body between frame rails and looking at parts. The deuce is tighter in a lot of spots and you just can't sit up, but it's high enough that you can't lay flat on your back and reach stuff, so you have to sort support yourself and get to things or rest your head on frame rails and get your hair (or bald spots) dirty. :)
