10 ton near Carrollton
rizzo
Port Huron, MI
I drove by one the other day. Not for sale, just parked where I could see it. Does a SS member own this? I'm just curious.
I'm not being very specific describing the location on purpose.
5,145
Wow, I've only seen 10 tons in pics, but seeing that 5 ton next to it really puts them in perspective. :shock:
indy4x4fab
Banned
1,711
41
indy, indiana
I think the one I pictured is an M123C.
What is the difference between the M123C and M123A2C?
Sorry m123a1c I mean, they have the refitted cummins diesel engine in them, not the gasser engine.
engine- m123 LeRoi T-H844 V8 Gas 297hp@2600rpm
engine- m123a1c Cummins P1525 V8-300 785 cu in, diesel 300hp@3000rpm
Transmission- Constant mesh Mack TRD XT72 5 fwd, 1 rev
Transfer case- Mack constant mesh 2 speed (integrated w/transmission)
Front Axle Mack- triple reduction
Rear Axles- Mack double reduction
Differentials- Mack 10:1
Winch- Garwood 45,000 lbs
Fuel capacity- 2 tanks, 83 gal each
Cruising range- 300-350 miles
Maximum speed- 43 mph
Weight- M123- 32,250 lbs
Weight- M123A1C 29,100 lbs
Length- 289 inches (7.34 m)
Width- 114 inches
Height M123- 113 inches
Height M123A1C- 108 inches
Towed load rating- 120,000 lbs highway / 80,000 lbs off highway
73m819
328
gainesville, ga.
Sorry m123a1c I mean, they have the refitted mack diesel engine in them, not the gasser engine.
m123 gasser
m123a1c Cummins V8300 diesel
never had a mack , either had a gasser OR 300 cummins
m123 ment gasser, double winches
C model ment single winch, lower 5th whell
D model ment double winches, lower 5t wheel
A1 ment Cummins power, built with the cummins, not refitted
So a m123a1c was a cummins power, single winch, lower 5t wheel
As far as I can find there is NO m123a2c, though I may be wrong
I did find that there is a m123e2, cummins power, duel winches, low 5t wheel, warning beacon, rear facing turn signles on the rear slope of the front fender, clearance lights
indy4x4fab
Banned
1,711
41
indy, indiana
Fixed sorry.
Found this videos.
Cummins diesels.
[media]http://www.youtube.com/watch?v=n_-BXN8Che0[/media]
[media]http://www.youtube.com/watch?v=6ThH0OtRfMg&feature=related[/media]
This is a gasser its one of 71 dirts trucks.
[media]http://www.youtube.com/watch?v=mmkDioE4UhY[/media]
maddawg308
814
Appomattox, VA
BKubu chimed in long ago in another thread, the M123 (any type) is always cool to look at. Not cool to drive or maintain. He owned a M125 cargo variant, says it would kill road signs even with his left wheel on the center line.
bkwudzhom
ga
Dads neighbor in south Ga has one that was used on the farm. The farm hands were driving it and it started knocking. I guess the knocking sound didn't translate into spanish for "FREAKING STOP!!!!!" so they kept driving until the broken rod beat a hole in the block!!!! I keep trying to buy it but he wont let it go.
123mack
11
Jemison, AL
The gasser in the third video was mine. I sold it to Dirt71 and bought a M816. The M123 I sold him was made in June 1956 according to the Mack factory.
Gunner0311
Millington, Michigan
Nice!
Looks a lot like my M52A2 before I removed the 5th wheel and attached a shortened
cargo box.
I like the step in the middle of the bumper.
I added one by welding up some one inch square tubing, just at the point the
bumper begins to angle back.
Remember: Bigger is Better!:beer:
spicergear
Millerstown, PA
I like the 10 tons too, and that monster winch, WOW. After reading about them on the Van Nettas (sp?) logging website however, I'm not a huge fan of the monster transmission set up they have. I would lose the whole drivetrain and start frest with different engine w/road ranger and prolly a 5 ton t-case. The 475hp Silver 92 and 13speed overdrive Road Ranger would be a nice start...
rizzo
Port Huron, MI
x2
I think that is the website that had pics of the spider gears turned to rubble.
supermechanic
poconos, pa
Spicer, I would not worry about the trans.
Mack triple-counter-shaft transmission is near indestructible.
Same setup was used on my 35 ton end dump,(quarry dump ,like a Euclid) dozens of different drivers over 30 years couldn't kill it.
