- 10,883
- 814
- Appomattox, VA
Well, got the test bench, well ok it's the dinner table, set up the other day to test a few PRC-25 and PRC-77 radios that customers wanted me to realign and test out, make sure they were good functioning radios. I have all the tools needed to test these out, but it is a complicated process that requires special tools.
The first pic below shows the test setup. In the middle, is AMGeneral's PRC-25 radio. The battery pack on top of the radio is made by Brooke Clarke, from PRC68.com, it uses 10 "D" cell batteries instead of the more common lithium or magnesium batteries that the 25/77 uses, as most of them were made long ago and are now dead as a doorknob. Simply snap in 10 batteries, insert as normal, and you're set to go.
On the left is the AN/GRM-55A module test set. These are test sets that use a probe and a set of easy-to-follow, but numerous instructions to test all the modules of the radio set and thereby narrowing down what is wrong with the radio's receiver, transmitter, or synthesizer decks. These test sets are uncommon, but could be found on eBay once in a while for $50-75 each. The instructions on how to use it are actually part of the unit, screened on aluminum plates bolted to the test set.
On the right is the rare AN/PRM-34 test set. This is not often found on eBay, or anywhere else. They are rare as hen's teeth, and I don't know anyone else who has one, much less for sale. The only way I got one was lucking out and finding one in a batch of surplus from GL about 6 years back. Still had a working battery in it too. Anyways, this test set is a combination wattmeter, frequency meter, and signal strength meter for any VRC-12 radio set, including the PRC-25/77, RT-524, PRC-68, etc. It is able to quickly diagnose what the transmit freq. is compared to what the radio dial says, test the forward and reverse transmit power in watts, and check the signal strength of the radio with the antenna in place. Very useful, although other test gear could be used for this purpose as well in place of the PRM-34.
Front and center, are the manuals for everything I had to use. If you do ANY radio testing, having manuals, in printed form (not .pdf) are irreplaceable for proper operation and maintenance of the gear.
Second pic shows same setup with a commercial frequency counter to more accurately check out the broadcasting freq. versus what the radio dial says. In other words, if the radio dial says 50.00 MHz, and the freq. counter says 49.99916 MHz, then the radio is only 840 Hz off frequency. This may seem like a lot, but even if the radio is 1 or 2 kHz off center, this is within spec, since the freq. bandwidth of the 25/77 is 9 kHz wide, 1 or 2 kHz off would still put the majority of the signal around your desired center freq.
Third pics shows the -25 taken apart and the GRM-55A test set plugged into a module. This is radio surgery, and this is what it looks like. Avert your eyes if it make you queasy.
Oh, and AMG's radio? Passed the transmitting test, but failed numerous receive and synthesizer tests, which would explain why he can't hear anything and noone can hear his voice on transmit. Out of about 30 tests the GRM-55 covers, his radio failed 14 of them. This doesn't mean that 14 modules are bad, it could only be one, which affects a bunch of other tests. We'll get it all sorted out and fixed for him soon.
