84cucv1ton
- 0
- 36
- New Jersey
did what was put here... same problem still. whats the nest step.. going to look at some tms
Sure, electricity is lazy! It will allways take the easeist path to ground. Haven't you ever seen an oncomeing car with one brite headlight and the other just kinda glowing real dim? That could be a bad ground not saying it is just could be.. Back feed through the grounds? That's no one on me.
Or a non-isolated ground relay? In the stock system, there must be *NO* conductivity between the GP relay mounting tabs and any of the terminals, otherwise bad things can happen....You said the GP's are getting constant volts? Is the relay stuck? Or hooked up wrong? Are you sure that black wire with the red butt splice is a ground and not power?
I presume you are talking about the two-wire exciter plug? If so, then just about any auto parts house should have them in stock.Could someone tell me on generator 2. The white plug that goes in the top of the alternator. Where can I find that Plug?...
