Lieutenant Dan
- 6
- 18
- Reading Pa
Ok so I picked up a hmmwv hydraulic winch a few weeks ago and mounted it on my deuce. I bought a LDS power steering pump (vickers vtm42). I got it mounted today and all hooked up. The pump whines around 1200 to 1500 rpm. The winch works great under no load. Once the engine reaches that rpm it starts making the god awful noise. I pulled it apart to check for irregular gear wear as I've read on two different types of timing gears. All was fine. I also pulled the pump apart again to make sure everything was fine on the inside since I flipped the rotation of the pump to left hand drive instead of right. All was fine there too.
The pump is plumbed with a 1 gallon reservoir above the suction port. The suction lines are 1/2" hose with 1/2" npt fittings on the ends. The pump has a 3/4" inlet. The outlet is 6 jic and I used 3/8" lines to the winch valve and to the cooler back to the tank.
I haven't put the winch under a load yet and I also didn't bleed the system but after about 30 seconds of the engine running the winch started to work. I did notice the tank oil was quite foamy.
My pump is rated for 5 gpm and 2000 psi which might be a bit high but should be OK for now.
So I don't understand why it's whining. Is it just air in the system? Is something wrong? Is my tank to small? Is the suction line to small? I've read in the tm that the winch valve has a 3.5 gpm restrictor in it so is that creating to much pressure at at 1200 to 1500 rpm and going through the internal relief valve of the pump? It's really frustrating now and I'm ready to lose my cool. Any help would be greatly appreciated!
