SUPERSPORT
- 2
- 18
- Ohio
What fuel line to buy? Fixed, page 3.
1991 M923A2.
Fuel line from copper line out of tank to big fuel filter. It was wet down where it connects to copper line. Tracking down my lose of prime.
Went to the 3 places around here I know of to try and get a new one made or new hose for my fittings. No help and they all named other places I already knew of.
Parker acted like they didn't have the fittings and would have to order. Cost about $55.
I read the sticky above with spread sheet. The Parker fitting it shows looks just like mine so I don't see why he couldn't re-use it. The hose he said I needed was gray. The hose in the sticky is blue and calls for HY fittings for diesel. Not the 82 series the sticky has listed and like I have. Sticky also doesn't list the 90* fitting on the other end.
1. Anyway, Exactly what hose do I need and where to get it? Is it 1/2" I.D.?
2. Another thing, Anyone just run a rubber line straight from tank to filter? Do away with the copper section?
3. I pulled the pick up tube up from tank to check it, fine. Anyway, what kind if sealant do you use on those threads? It had something like pipe dope on it but was dried out and crumbled to dust.
1991 M923A2.
