replacement door handle trips
MGKMartin
23
Portland, OR
Is there any interest in replacement door handle trips made from cast bronze with the thin area reinforced? These would work with either the pull-up or pull-down handles and would be a direct replacement for the cheap cast aluminum trips that always break. Likely cost would be $75 each but that would come down if enough people are interested.
Awesomeness
1,522
Orlando, FL
Why bronze? I was thinking of making some too, but was just going to use CNC machined billet aluminum or steel, for probably roughly the same price. I'm curious if your way would be better or not.
TNriverjet
24
Clifton, TN
As a data point for comparison, I purchased a NOS passenger door handle with keys from a reputable SS vendor for about $210. This was over $100 less than auction site prices at that time. A "sub $100" price tag would be much more reasonable and I am now subscribed.
MGKMartin
23
Portland, OR
For the why bronze question, it is a matter of cost. It is strong enough for this application and significantly cheaper than a machined part. I had my drivers side trip machined out of 4140 and I can have the molds built and ~10 trips cast for what that cost. The mold tree does 20 trips (10 of each trip) so it is quite a bit more expensive than the 1 that I need for my passenger side, but this is a part that is a known-bad design that fails. I figured that there were a lot of others out there that had a broken trip and might need one to get their door handle working again. If there is enough interest that I don't loose money, I will have a batch run. If not, I will just machine my passenger trip out of 4140.
Final price will depend on interest, but they will likely be between $50 and $75 each.
scottmandu
36
Texas
I've found out the trips aren't the weak link, rather the catches bind up due to wearing out/dirt accumulation which causes stress on the door handle assembly. A bad catch will break even a new door handle quickly.
