CUCV early Glow Plug burn out - What is the cause?
Commander5993
I got the answer to getting that steel line on...don't tighten the pump to the block...just start the bolts and start the steel line at the same time...get it screwed on almost all the way then tighten the bolts to the block. If need be I think there's a stud that holds the steel line tight to the block...can pop that loose too. As far as the glow plug card you don't need to remove the card or do much other than wire a ground switch to the second wire in the gp harness...can get the wait light if you hit the third wire too. Push button in the cig lighter spot.
Thanks so much for the tips, now that you brought that up I think that I may have done that originally with the line. Also the rod didn't fall out this time, I even felt in there a bit and didn't feel anything. But I thought it was just my memory crossing over to something else I had worked on.
That pushrod can't "pop out" and go down into the engine can it??
It may have just been stuck in there with some oil build up or something and was enough to keep it from falling out. Guess I'm going to have to take the pump back off now to find out. Which I'd have to take it loose to install the line anyway.
WWRD99
1,918
York Pa
I don't think I've ever done a pump where that shaft didn't fall down into the cover pocket. I always pop it out and cover it in grease. I hope it did stay up, though, because you probably bent the pump bolting it together. Thing is you'd really have to ramajammit in with the block bolts...that steel line is a simple 3/8 brake line. Can make them pretty easy. Doing these on the ground is tough...just high enough to be hard to reach. Luckily my son and I have that part down pat since we replaced all of ours and got the last one to 20 minutes.
Commander5993
Hey all, been a few months. been dealing with health issues and etc.
anyway, worked on this fuel system again today. I got the pump on last week after 3 previous days wasted on it. But screwed up the first new hardline I bought. So bought another piece of 3/8" brake line and tried again. Had that fixed this time... until I got tee'd off and went to rip out a hose, and of course it caught the line and kinked it. i dont expect anything less these days. I'll fix it again.
But I have another question. Either I am completely thinking of this @s backwards, or I'm right and it ain't working.
After getting the hard line installed and connected, and changed truck batteries as the others were 4+ years old and getting weaker. I removed pink wire off injection pump and cranked the engine. Reinstalled pink wire, as I've done before, cranked but nothing. Did that several times, nothing. Then I opened the vent on the fuel filter, cranked truck, no fuel coming out drain hose. Did that a few times, with vent closed and open, never got fuel. So Installed a new fuel filter, even though I was nearly certain that wasn't the issue because the filter wasn't that old. But just to eliminate it, replaced. Still got nothing.
So this is when I got the idea of using my vac pump to see if it would pull fuel, because I started thinking I must have screwed up the new lift pump. And on the vac pump, I got nearly 20 inches of vacuum, but no fuel.
I opened the drain vent on the fuel filter, then suddenly got a spurt of fuel. Pumped vac back up, removed drain hose from fuel filter housing, used the limp part of a rubber glove and held it up to drain port. Opened the vent, and it SUCKED the glove up to the drain port hole. Which... it should have blown air out, right?
So am I pulling a vac on the wrong hose or what? See photo, that hose is connected to fuel filter housing and normally is connected to the hard line that screws into the lift pump. That is the inlet hose isn't it? And not the return line??
Further, if this is the correct line, and yet I can't get any fuel... that means the issues is in the tank doesn't it.....
I just replaced the entire fuel tank, sending unit, sock, hoses, and etc about 3 years ago.
WWRD99
1,918
York Pa
Pull a vacuum from the bleeder on top of the filter housing, not the hoses. The plastic plug on top, unscrew that and hook to the output on the left side on top. Or just crack it and turn over the motor. It takes a bunch of cranks.
Commander5993
I forgot to say that I did try to pull a vacuum off the drain hose, with the drain/vent cap open of course. Didn't get anything there either.
Tomorrow I'll unscrew the plug on top and try to pull from there. And yeah, I know it takes some cranking, I've done it a number of times before through the years. But couldn't get anything today no matter what I did.
WWRD99
1,918
York Pa
I don't think you'll pull anything out of the bottom drain as it's for water not fuel. The top one is a direct port from the lift pump to the filter
Commander5993
I pulled from the top right line on the fuel filter, which is the line that goes to the lift pump. Is that what you're talking about?
I also tried to pull from the vent port i guess you'd call it, where normally you can open to release air until fuel begins flowing. Which that port is on the top left side of the fuel filter. Got nothing on either port though.
Commander5993
Well, apparently this lift pump is bad. Before I began digging further into the fuel system, I thought I would connect a hose to the hard line going to the lift pump, and drop the other end in a diesel can. Cranked truck with pink wire off fuel injection pump, fuel only lifted a couple feet from top the fuel can. I even sat the fuel can up on the engine bay, so it was basically level. Still didn't pull any fuel.
So I guess after all that work to replace this thing over these past few months, its was a bad pump out of the box. I've had "new" bad parts before, but this really aggravates me because of how difficult it is to install. But nothing I can do about it but buy another one now, as the return window closed months ago on this one.
Any other reason you guys know of for why it wouldn't' even pull fuel from a diesel can?
WWRD99
1,918
York Pa
It happens. I get surplus ones on ebay. Been working for years plus I got a few as backups.
Commander5993
Is Carter a good brand? You think the diaphragm and such are still good on NOS?
I bought a NOS fuel return hose kit, and they didn't last a year. Had to replace with new Viton hose.
The previous pump that was on the truck, which I installed around 2010, was a AC Delco. This one that was bad out of the box is a Delphi.
EDIT: WOW... i was way off, found my amazon order. I got that AC Delco in 2017.
WWRD99
1,918
York Pa
My first batch with this guy was late 2019. Those 2 trucks still have those pumps in them. He has pallets of these why they are so cheap. There's a small demand for it. How long should pumps last though? They only take 25 minutes to swap out.
87cr250r
2,131
Rodeo, Ca
There is a good chance you have the wrong lift pump. Take a look at the lever. The diesel uses the straight arm, first pic. The gas engines have a curve to the arm, second pic.
Commander5993
Ordered 3 of them just to keep a couple on hand, and because the shipping was the same for 1 or multiple.
Commander5993
Can you tell me which arm is right WWRD99 ?
* I'm attaching the pump thats been on the truck since 2017
** Then the one I installed on the truck in recent weeks that didn't work.
***Then the Carter one that I ordered from the link you dropped - it has the indented arm.
Commander5993
Ok, after a lot of headaches and further... "diagnoses"... I have come to the conclusion that I must be a dumb🫏
anyway, I have went through 3 new lift pumps
1st: installed the new Delphi... didn't work, figured pump was bad out of box. 😠
2nd: Installed, worked, truck ran, but a 90 degree flared to hose barb fuel fitting was leaking from threads/flared end. Attempted to tighten, ripped the entire inlet connector fitting off the fuel pump itself 😡 so that pump was garbage.
3rd: The current Carter Fuel pump still installed. Truck started for a min, surged, then died. No restart. 😡 😡
Decided to bypass lift pump with 12v electric pump, still no start.
By passed ENTIRE fuel system and connected directly to the hose going to Injection pump. STILL wouldn't restart.
Used a GRAVITY test fuel container that hangs up and has the hose on the bottom of 'bottle', connected it directly to the Injection Pump.
STILL NO RESTART! 🤬 🤬😤
Me thinking: How could it possibly Not start/run with the Entire fuel system bypassed... unless it's the injection pump itself. But if it was, why would it start and run at times...
The only thing left of the fuel system is the return line....
PULLED the return hose off fuel injection pump. Cranked for a couple seconds and BOOM fired up and ran fine, of course with fuel flowing out of the injection pump everywhere.
HOW could a fuel return line get blocked?????? It is CLEAN FUEL going back to the tank. It doesn't have any filters or anything that I've ever heard of, which wouldn't make sense anyway.
And I just replaced the ENTIRE fuel tank, sending unit, sock, etc etc about 3 years ago. INCLUDING the short fuel hoses that connected to the fuel sending unit to the hardlines. Haven't had any issues since then, and even then the only reason I replaced it was mostly because the sending unit causing the fuel gauge to be off, and it had gotten worse and worse over several years. So I wanted to fix it and ended up replacing everything else while i was at it.
Does anyone know of any location or problem that could cause a blockage in the fuel return lines???
WWRD99
1,918
York Pa
Me thinking: How could it possible to Not start/run with the Entire fuel system bypassed... unless it's the injection pump itself. But if it was, why would it start and run at times...
Not to bring up the past but back in February I mentioned to put a clear fuel line on the ip return. Blockage is easy to find. The steel line hooked to the ip line goes right under the passenger side alternator with a rubber hose connection. Can start there and see if fuel flows. Can jump back to the frame and try and get the line off the tank but that's a need a teenager thing to fit into...I don't fit in there. I think there is one rubber line on the frame for the return but I am not sure. Technically you should be able to blow air in the rubber line behind the alternator and see if air flows too. Don't hook up the the metal line on the IP. Could be the hose off the IP is bad too.
