Fmtv brake tools.
serpico760
1,586
San Diego, CA
These tools are expected to be made out of hot rolled steel. I'm going to try 3D printing them in carbon fiber polycarbonate and see how they do. You may download the SolidWorks or step file or STL file. I may offer them for sale later or if you're interested PM me for a 3D printed version.
FMTV Tools
serpico760
1,586
San Diego, CA
FMTV Tools
3D printing of one of the the brake tools nearly done. The inside has a gyroid pattern which is cool because you can fill it with epoxy which is what I will do once it's done printing. Gyroid is kind of like a Mobius strip in 3D form. Pouring in epoxy will go all the way to the bottom and then fill it all the way up to the top leaving no air pockets if it's not too thick.
serpico760
1,586
San Diego, CA
The brake plunger seal driver:
And the brake adjusting tool, or at least the guide for adjusting the brakes.
serpico760
1,586
San Diego, CA
Pretty cool. Do you sand blast them at all or are they 100% out of the printer?
That's 100% out of the printer. I've had very good results with this material, and using a gyroid infill you can easily fill it with polyester resin or some other epoxy. Then it's solid and hard. I'm not sure I need to though this material is so very hard and strong.
MatthewWBailey
Father, Husband and Barn Hermit
944
Mesa, Colorado
I'm afraid to ask what those printers range
serpico760
1,586
San Diego, CA
3D printers are not so expensive. Couple hundred dollars for a cheap Chinese one, but I don't buy cheap Chinese crap if I can avoid it. That's a Prusa printer made in Czech Republic. And no Chinese parts. They're just under a thousand and I've had it for 3 years. About $700 if you buy it as a kit and build it yourself
MatthewWBailey
944
Mesa, Colorado
I think I need one of those😂. Is it purely a thermoplastic material feed? You mentioned carbon fiber. I worked a lot in injection and compression molding as a menial programmer in the early 90's so am familiar with phenolic resins, but this is crazy stuff.
