- 1,514
- 4,209
- 113
- Portland, OR
I'm in for 7 at least.
Year and a half ago for last post... haven't heard of anything ever coming from this.I’m still in for 6 kits.
I would be interested, hopefully less then $100 each but that's not necessarily a deal breaker.Dana will be releasing a new CTIS Wheel Valve design that will be compatible with the LMTV systems. The valve will only be sold to OEM for current production. However if there is enough interest we could market a rebuild kit. The advantage of the replacements parts is a new diaphragm that will perform to -35 deg F. and last much longer. The new design is also impervious to water and moisture. Please let me know your interest in this kit and what a fair price point might be. The kit would include the following: New vented lid w/4 screws, new diaphragm, new spring, and a small bracket to protect the lid vent. As this would be purchased through a dealer I could be $100 per valve retail.
The kit is now in the Dana Aftermarket system but they will need to see orders before they will build and stock them. Unfortunately I do not have the SRP yet. The kit includes a new diaphragm that will not fail in the cold or cause corrosion. This includes a vented cover and protective bracket for proper function, and 4 new screws. PN 505295Dana will be releasing a new CTIS Wheel Valve design that will be compatible with the LMTV systems. The valve will only be sold to OEM for current production. However if there is enough interest we could market a rebuild kit. The advantage of the replacements parts is a new diaphragm that will perform to -35 deg F. and last much longer. The new design is also impervious to water and moisture. Please let me know your interest in this kit and what a fair price point might be. The kit would include the following: New vented lid w/4 screws, new diaphragm, new spring, and a small bracket to protect the lid vent. As this would be purchased through a dealer.
No they do not sell separate sub-componentsWill there be an NSN for this kit as well?
Is there a part number for the diaphragm by itself?
This is a good question. The selling entity would need to have an account set up with Dana Crossville Aftermarket the same as a truck parts distributer. I do know that every hand that touches a part increases the cost so maybe someone on this site has access to an account.Can anyone purchase from the Dana after market or do we have to purchase from a distributor?
National Stock Number (NSN), or National Item Identification Number (NIIN) are the government part numbers that are issued to make the parts available in the system to the military branches and government agencies.No they do not sell separate sub-components
What is an NSN?
Right forgot. If Depo's or DLA buy the kits I am sure they issue a number but it is too early yet.National Stock Number (NSN), or National Item Identification Number (NIIN) are the government part numbers that are issued to make the parts available in the system to the military branches and government agencies.
