Dark Seas M1008 Project
WWRD99
1,850
York Pa
These dorman ones are viton. Used them many times. You'll still need the end caps though...2 of them one for each side.
Sent from my SM-S906U using Tapatalk
87cr250r
2,050
Rodeo, Ca
I forget if the tube is 1/8" or 3mm. Everything else is metric so it must be, right? 3mm will fit a little tighter.
Arizona
Little bit of an update since memorial day...
I got a new coolant overflow jug in from RockAuto and put it on yesterday. The original bracket didn't like the angled mount of the new jug (old jug mount just went straight up, this one is at like a 45 degree angle), so I ziptied it in a few spots for now just to hold it still and upright, seemed to hold just fine.
I also took the time to unhook the batteries and flip them. I'm pretty sure my GEN1 works and my GEN2 needs some behind the dash troubleshooting, so for now I figure every couple of weeks swap the batteries so that they can charge up on the GEN1 alternator. Prior to messing with anything, the GEN1 light came on with the key and turned off when the truck started (you're about to see why this matters)
Of course, upon flipping the batteries and changing the coolant jug out I caused myself a new problem... my GEN1 light doesn't come on anymore with the key. The truck started, so I know I have the batteries connected correctly, or else it wouldn't have had 24V to start. The fuel pump (12V) and glow plugs (I could hear a change in fuel pump tone when activating the GP) both seem operational with the key in on position, it's just the GEN1 light that's out. Weird. I'm getting a multimeter today, it's due time I dig into charging system anyway...
Full info of what changed: I disconnected the batteries and swapped the battery positions front/back. I replaced coolant overflow jug and removed the original's bracket. When I got the bracket for the old jug off, I found a small ground (I think for the headlight/LED pod light) tucked in behind the washer and bolt that held the bracket to the radiator support. I put this ground back with the same bolt and washer after removing the bracket -- my headlights and turn signals and everything worked fine when I fired her up, I just noticed my GEN1 light was no longer glowing before startup.
Next steps:
1. Maybe the GEN1 light isn't coming on because the "depleted" battery doesn't have enough voltage? -- The batteries are only about a year old, the front battery was depleted from ~20 truck starts. Truck still starts fine and all the 12V accessories still work. Will check both batteries voltage with multimeter. If that's the case and that battery voltage is "low", the GEN1 might not be getting excited and charging.
2. The heater fuse might be out, I have spare fuses in the truck, that'd be an easy test and fix.
3. With the truck running, is she getting ~14.5V at the 12V battery? I'd like to see if it's just a bulb issue and the alternators working fine/the GEN1 light will return after a drive or two.. I doubt I will get that lucky though, dash lights seem pretty critical to normal operation of the alternators...
4. Maybe the bulb died? I feel like that'd be less likely than the GEN2 bulb (which had probably glowed for years when the truck was converted to 12V)
5. Other ideas?
DarkSeas
318
Leland, N.C.
Bit of a win today. Bought this Badger Diesel return line kit off Amazon for about $22. Guy from SS on Youtube recommended it. Put the kits cap on the back passenger injector, pulled the old line, sized, and cut a new return line to replace the one that was leaking.
No pesky hose clamps necessary. I didnt think the lines even really seated that well I was nervous but I fired her up for the first time in a few weeks and she's been idling without a drop of diesel on the ground for about 10 minutes
I'll be replacing the rest of the lines throughout this weekend. Pics:
Edit to add: Tim's Teachable Moments on YT. He's a SS member. Tim if you're seeing this, thanks. Tim's YT video about this exact issue
87cr250r
2,050
Rodeo, Ca
I've seen that hose material before. It will be hard and full of cracks within 10k mi. Look at the lettering on the hose. If you see NBR, that's nitrile rubber and it doesn't tolerate the heat associated with injector return lines.
DarkSeas
318
Leland, N.C.
I'm okay with more frequent changeouts. Or even keeping a roll of this handy for a temporary fix to a leaking line if I get some better line and hose clamps in someday. I just needed something cheap and easy to get her running again without dumping diesel everywhere at my apartments.
Something to get me by on occasional weekend short backroad cruises till I move next Feb. Also something to keep the apartment people away from towing it since they "haven't seen it move in a month"
Editing to add: I don't even think I've put 500-1000 miles on the odometer since I got her running and home this time last year.
DarkSeas
318
Leland, N.C.
I remember base cops chalking the tires on my Datsuns because the tow company wanted them. It's not much fun. Hope your next living situation is better.
Appreciate it man. It will be actually. Gonna move back to Maryland live with my wife's folks for a couple years. After we got married last october her dad pulled me aside and said "we plan on selling our house soon now that its about paid off but we want to give you guys the opportunity to move back home and live here a couple of years to save up for your own house. We will renovate the basement into an apartment for you guys, and you can stay here for free. We want you guys to save up and put enough down on a house where youre able to pay it off like we are in our 50s."
Offer I cant refuse given the current market. Also her parents are actually really cool so no in law hell where I'm going.
Her dad will probably even help me work on the CUCV. My wife's little brother wants nothing to do with workin on cars and her dad was super into it back in the day.
