Milatary Construction & Earth Moving Equipment, All types
Guyfang
26,410
Burgkunstadt, Germany
This is The Thread, for Military Construction Equipment, Earth Moving Equipment, All Types and associated info, to simplify finding them in the Technical Manual, Forum. Each Post, below this one, will include a different Publication or TM. As new documents are Posted, this thread will be updated.
I would like to thank members @tim292stro , @cberrier , for their contributions.
Please take the time to look at the cover page to each document to make sure it covers your Equipment.
Guyfang
26,410
CATERPILLAR MODEL D7F
TRACTOR, FULL TRACKED, LOW SPEED: DED, MEDIUM DRAWBAR PULL TRACTOR WITH RIPPER; NSN 2410-00-185-9794 (EIC: EAW)
TRACTOR WITH RIPPER AND WINTERIZED CAB; NSN 2410-00-300-6665 TRACTOR WITH WINCH; NSN 2410-00-185-9792 (EIC: EA6)
TRACTOR WITH WINCH AND WINTERIZED CAB; NSN 2410-00-300-6664
LO 5-2410-233-12 dated 1983
TM 5-2410-233-10 dated 2005
TM 5-2410-233-23 dated 2005
TM 5-2410-233-23P dated 2005
TM 5-2410-233-34 dated 1972 wc#2
Guyfang
26,410
CATERPILLAR MODEL D8K
TRACTOR, FULL TRACKED, LOW SPEED, HEAVY DRAWBAR PULL, (SIZE T-11) W/ANGLE DOZER, WINCH AND ROPS, CATERPILLAR MODEL D8K-8A-58 (CCE) NSN: 2410-00-574-7597, AND W/BULLDOZER (SEMI-U-TILT), RIPPER, AND ROPS CATERPILLAR MODEL D8K-8S-8 (CCE) NSN: 2410-00-574-7598
TM 5-2410-234-14&P-1 dated 1981 wc#1 Part 1
TM 5-2410-234-14&P-1 dated 1981 wc#1 Part 2
TM 5-2410-234-14&P-1 dated 1981 wc#1 Part 3
TM 5-2410-234-14&P-2 dated 1981 Part 1
TM 5-2410-234-20P dated 1988
TM 5-2410-234-34P dated 2001 wc#2
Guyfang
26,410
CATERPILLAR D7G
T R A C T O R , F U L L T R A C K E D , L O W S P E E D : D E D , M E D I U M D R A W B A R P U L L , S S N M 0 6 1, T R A C T O R W I T H
R I P P E R , N S N: 2 4 1 0 - 0 1 - 2 2 3 - 0 3 5 0, T R A C T O R W I T H W I N C H , N S N: 2 4 1 0 - 0 1 - 2 2 3 - 7 2 6 1, T R A C T O R
W I T H R I P P E R A N D W I N T E R I Z E D C A B , N S N: 2 4 1 0 - 0 1 - 2 5 3 - 2 1 1 8, T R A C T O R W I T H W I N C H A N D
W I N T E R I Z E D C A B , N S N 2 4 1 0 - 0 1 - 2 5 3 - 2 1 1 7
LO 5-2410-237-12 dated 1992
TM 5-2410-237-10 dated 1993 wc#2
TM 5-2410-237-10-HR dated 1992
TM 5-2410-237-23 dated 2005
TM 5-2410-237-23P dated 2005
TM 5-2410-237-34 dated 1993
TM 55-2410-237-14 dated 1990
Guyfang
26,410
JOHN DEERE MODEL JD410(CCE), TRACTOR, WHEELED, DED LOADER BACKHOE, WITH HYDRAULIC IMPACT TOOL , WITH HYDRAULIC EARTH AUGER ATTACHMENT, WITH BUCKET, IMPACTOR, AND EARTH DRILL, NSN 2420-00-567-0135
LO 5-2420-222-12 dated 1992
TM 5-2420-222-10 dated 1985
TM 5-2420-222-20-1 dated 1987 wc#1
TM 5-2420-222-20-2 dated 1987 wc#1
TM 5-2420-222-20-3 dated 1987 wc#1
TM 5-2420-222-20P dated 1992 wc#1
TM 5-2420-222-34 dated 1992 wc#1
TM 5-2420-222-34P dated 1992 wc#1
Guyfang
26,410
Poster Note: For those looking for 5.9L Cummins 6BT engine Shop Manual and Troubleshooting Guide for 91-94 vintage engines this TM contains both full books.
HIMEE (INTERIM HIGH-MOBILITY ENGINEER EXCAVATOR)
TRACTOR, WHEELED, INDUSTRIAL
TM 5-2420-230-10 dated 2003
TM 5-2420-230-24P dated 2005
TM 5-2420-230-24-2 dated 2003
TB 5-2420-230-14 dated 2003
Poster Note: For those looking for 5.9L Cummins 6BT engine Shop Manual and Troubleshooting Guide for 91-94 vintage engines this TM, (TM 5-2420-230-24-2) contains both full books.
Guyfang
26,410
DEUCE (Deployable Universal Combat Earthmover 30/30, Model DV100
TM 5-2430-200-10 dated 2001
TM 5-2430-200-24 dated 2001 Part 1
TM 5-2430-200-24 dated 2001 Part 2
TM 5-2430-200-24P dated 2001
Guyfang
26,410
I H C (International Harvester) M O D E L: H 1 0 O C , Type I & Type II
L O A D E R , S C O O P T Y P E , D E D , 4 x 4 , A R T I C U L A T E D F R A M E S T E E R , 4 1 / 2 t o 5 C U . Y D . , ( C C E ) ( I H C M O D E L H 1 0 O C ) : T Y P E I W I T H 4 1 / 2 C U . Y D . B U C K E T, NSN 3805-01-052-9042, T Y P E I I W I T H 5 C U . Y D . G E N E R A L
P U R P O S E B U C K E T, NSN 3805-01-052-9043
TM 5-3805-255-14&P dated 1980 wc#1
TM 5-3805-255-14&P dated 1988 wc#1
TM 5-3805-255-34P dated 1988 wc#1
Guyfang
26,410
CLARK MODEL 175, Type I & CLARK MODEL 175, TYPE II
LOADER, SCOOP TYPE, DED, 4 X 4, ARTICULATED, FRAME STEER, 4 1/2 to 5 CUBIC YARD (CCE), TYPE I WITH 4 1/2 CU. YD. BUCKET
NSN 3805-00-602-5006, CLARK MODEL 175, TYPE II WITH 5 CU. YD. GENERAL PURPOSE BUCKET, NSN 3805-00-602-5013
TM 5-3805-257-24&P dated 1981 wc#2
TM 5-3805-257-24P dated 1993
Guyfang
26,410
L O A D E R, SCOOP TYPE, DED 4 X 4, A R T I C U L A T E D F R A M E S T E E R , 2 1 / 2 C U B I C Y A R D B U C K E T ( C C E ) ,
A I R B O R N E / A I R M O B I L E , S E C T I O N A L I Z E D AND N O N S E C T I O N A L I Z E D
M O D E L : 9 5 0 B S
N S N: 3 8 0 5 - 0 1 - 1 2 6 - 7 9 1 4
M O D E L: 9 5 0 B S C E
N S N: 3 8 0 5 - 0 1 - 2 6 0 - 5 1 6 2
M O D E L: 9 5 0 B N S
N S N: 3 8 0 5 - 0 1 - 1 2 6 - 7 9 1 5
M O D E L: 9 5 0 B N S C E
N S N: 3 8 0 5 - 0 1 - 2 6 0 - 5 1 6 3
TM 5-3805-258-10 dated 1991
TM 5-3805-258-24-1 dated 1991
TM 5-3805-258-24-2 dated 1991
Guyfang
26,410
CATERPILLAR MODEL 130G
GRADER, HEAVY, ROAD, MOTORIZED, (NSN 3805-01-150-4795)
LO 5-3805-261-12 dated 1992
TM 5-3805-261-10 dated 1989 wc#2
TM 5-3805-261-20 dated 1992 wc#1
TM 5-3805-261-24P dated 1993
TM 5-3805-261-34 dated 1989 wc#1
TM 55-3805-261-14 dated 1986
Guyfang
26,410
J.I. Case Model MW24C
O P E R A T O R ’ S M A N U A L, L O A D E R , S C O O P T Y P E , 4 x 4 , A R T I C U L A T E D F R A M E 2 - 1 / 2 C U B I C Y A R D, D E D
S T E E R , ( N S N 3 8 0 5 - 0 1 - 1 5 0 - 4 8 1 4 )
LO 5-3805-262-12 dated 1986
TM 5-3905-262-10 dated 1987 wc#1
TM 5-3905-262-20 dated 1987 wc#1
TM 5-3905-262-24P dated 1982 wc#2
TM 5-3905-262-34 dated 1987 wc#1
TM 55-3805-262-14 dated 1986 wc#1
Guyfang
26,410
ACE, (ARMORED COMBAT EARTHMOVER), M-9
NSN: 2350-00-808-7100
LO5-2350-262-10 dated 1993
TM 5-2350-262-10 dated 1992 wc#6
TM 5-2350-262-10-HR dated 2000
TM 5-2350-262-20-1 dated 1997 wc#3
TM 5-2350-262-20-2 dated 1997 wc#3
TM 5-2350-262-20-3 dated 1997 wc#2
TM 5-2350-262-24P dated 2000
TM 5-2350-262-34 dated 1997 wc#2
TM 5-2815-240-34P dated 1991 wc#3
MWO 5-2350-262-35-1 dated 2005
TM 55-2350-262-14 dated 1992
Guyfang
26,410
CATERPILLAR D9R
These documents seem to be an extract for an Caterpiller TECHNICAL PRESENTATION. The first document is the presentation, and the second are the Pictures/Slides that would have been shown to the "Students)
SESV 1669-91 dated 2000
SLID 1669S CAT D9R dated 2000
