MEP004a Access Panel
McKeelo
Upland, CA
Hello, just acquired an Mep004a and it is missing the bottom half of the access panel on the electrical connection side. This is the door that covers the main lugs.Im hoping someone here can help me locate one. I’m in Southern California. Thanks everyone!
Guyfang
26,027
Burgkunstadt, Germany
They are tough to find. If someone is parting out a set, you might get lucky. It was not a stocked part, and was difficult to get, other then through cannibalization.
Figure 13, Item number: 22 XBOZZ (This code tells you that its not stocked and that cannibalization is how to get it.) Item name: DOOR,LEFT REAR Number in unit: EA 1
Part number:72-2107 or: 30554-72-3107
Good luck
McKeelo
Upland, CA
Good luck
Thanks for the info!
