WI MEP-804A MEP-804B MEP-805A MEP-806A TRC Voltage Regulator TQG Military Generator
GIJoeCzar
29
Sherwood, WI
main photo.jpgPXL_20250106_170249274.jpgPXL_20250106_170503638.jpgGenuine Technology Research Corporation (TRC) voltage regulator for US Military Tactical Quiet Generator (TQG) models MEP-804A, MEP-804B, MEP-805A, and MEP-806A that are equipped with the TRC voltage regulator. I've reduced these to $225 (shipping to the Lower 48 INCLUDED) because the few I have left have some plastic ears/tabs broken off; these are the plastic pieces that go between the terminal screws and does not negatively effect operation.
This voltage regulator is the correct USGI voltage regulator for the MEP-804A or MEP-804B or MEP-805A or MEP-806A, so long as the generator is currently equipped with a TRC voltage regulator. If you have a generator with a Libby-equipped voltage regulator please look elsewhere, as this voltage regulator WILL NOT WORK; I’m not an electrical engineer, so don’t know “why” you can’t mix and match Libby and TRC parts, all that I know is that if you mix and match Libby and TRC parts you’ll destroy something in your generator.
This is a brand new factory TRC voltage regulator that has been professionally converted from 400Hz to 60Hz. This voltage regulator is genuine USGI, so it does support parallel operation and load sharing.
I test each of these voltage regulators in my TRC voltage regulator equipped MEP-804B generator to ensure proper function before I ship, but I have absolutely zero control over what you do with it when you receive it, so there is no warranty included with this voltage regulator – please make your decision to purchase accordingly. The only accepted forms of payment are cash, PP F&F, Zelle, wire, or any form of money order or check (but will wait 10 business days to clear before I can ship).
Often times I do not get notified of steelsoldiers messages, so please email me if interested: joe@armytruckparts.com
PXL_20210605_123614844.jpgPXL_20210605_123623396.jpgPXL_20210605_123628764.jpgPXL_20210605_123632780.jpgPXL_20210605_123708192.jpgPXL_20210605_123720461.jpgPXL_20210605_123727366.jpgPXL_20210605_123741404.jpg
