- 17,860
- 26,710
- 113
- Burgkunstadt, Germany
Military Load Banks & Civilian Load Banks the Military uses, or has used. The Load Bank Test Requirements document is an example of how young soldiers are taught to Load Test a generator. No generator is considered repaired unless its been load tested, at least several hours. The Load Bank is also the best way to "cure" a generator of Wet Stacking.
I would like to thank member @155mm for his contributions.
