Some M1010 Camper Box Mods
chevymike
485
San Diego, CA
So I haven't really shared that much of my M1010 camper build, as it's not for everyone. Some will scorn at me, others think it's cool. I am building my own camper the way I want, so that's good enough for me. Thought I might share a couple big box mods I have been working on.
This is the completed roof raise. I added 8". Built framing for all four side and then sheet aluminum for the main panels. Bent corner pieces with a homemade die on my press. Came out nice and I can stand upright inside. :giggle:
Finishing up a new rear wall with the doors removed and adding a single camper door in the middle. Built framework and sheeted with aluminum.
All of the added framework and sheet is held with Sikaflex adhesive/sealant and structural rivets. My full build thread is in my signature, if you're interested.
ANGRET
Raymond,CA
I'm not too familiar with the site so I apologize if I'm messing up. I'm thinking a buy a M1010. It doesn't have the original litter and bunk setup. I would like to restore it to original. Do you have or know someone that is getting rid of the OEM stuff?
chevymike
485
San Diego, CA
No sadly I don't. I would say to search for CUCV groups on Facebook and you might find folks who are selling parts. My first M1010, which was totally stock in the back (this was 10 years ago), I sold a bunch of the parts I pulled out to someone. So it does happen but it's finding the person selling them.
mikev
73
Culleoka, TN
I did the same - went the "other" direction to "original" (though chevymike is going to have a nice, personalized camper when he's done...)...
That said, mine was missing pads and a couple of "ceiling" litters, brackets, straps, etc. I bought the contents of a M1010 box from John at Hillbilly Wizard in PA. Now my box is complete.
Parts can be found at Hillbilly Wizard, eBay, Craigslist (use searchtempest.com for nationwide searches), 4WD and Offroad forums and Facebook Marketplace. There are a few Facebook groups that are specific M1010, but I can't recall the names or links.
The good news for you is more guys are converting to campers vs restoring to stock configuration, so you just have to search daily and get the word out what you need before "valuable" parts are tossed or sold for scrap...
Good luck!
ballencd
100
Columbus, NC
I just bought a M1010. I am planing on a camper build and don't know what I will be removing from my truck yet but I may have some parts for sale. I am just now trying to get it running. It has been sitting in a barn for a few years and has a few problems. Fuel shutoff solenoid, flex plate teeth messed up, horn inop, headlights inop, harmonic balancer (old) and glow plugs inop......
I found the fuel shutoff solenoid was bad and replaced it. It will start now but I had to use ether. Smoked a lot but is settling down some.. Time will tell. It came with a new flex plate but I have not swapped it yet....soon. I have a harmonic balancer on order from Rock Auto. I think I have figured out the horn and the lights have been fixed. I am planning on some solar panels, bed, kitchen, extra fuel, propane, roof rack, trailer hitch and hopefully something to aid in the fuel mileage and highway speeds.
ballencd
100
Columbus, NC
I have pulled the ambulance beds, steel racks in front of the beds, diesel heater and rolling seat for medic. Probably too far to ship to CA but they are available. I am installing a second 20 gal fuel tank now and looking into OD options as 55 at red line is too slow.
ballencd
100
Columbus, NC
I'm actually just finishing up the second tank install now because I had to custom fabricate the filler neck in the middle of travel soccer season and tennis season all before my youngest sons HS graduation.....it took me a long time. The fuel tank is the same one that fits the drivers side and the brackets and straps also match. I got them all from LMC. The chassis on the passenger side is already drilled for the tanks and there is a factory spot for the valve and gauge switch. All that is the easy part although I am still looking for a rock guard for the second tank it is mostly installed. I still need to hook the second tank to the valve which is in place and run some wires for the switch actuation. I used a filler neck from a M1009 and cut it down to work in this application. I'll try to drop some photos in here.
ballencd
100
Columbus, NC
My plan is to cover the new filler like the drivers side in the last picture. My welding is terrible, especially in the aluminum but I will get batter as the work progresses.
