M51A2 dump truck start system wiring help.
DREDnot
627
Avondale , AZ
Just digging into a new to me non runner
Has the LDS-465-1A multi fuel engine.
I spent the long weekend downloading ALL the TMs and going through them looking for the wiring diagrams.
I only found one and that was for the early gasser which doesnt match.
Mine seems to be a later 60s perhaps? It was last painted carc in 2003 so possible it had some later retrofitting like a larger primary fuel filter and who knows what.
We got it from BIA so who knows what "field expedients" were applied to it.
The start button is missing and may have been replaced with this abomination...
It has what looks like a start relay but seems to be missing a voltage regulator
It has an unknown condition fuel lift pump in the left tank but without a wiring diagram to look at I am not sure where it draws power from or when .
The truck is at a remote storage lot in 114 degree heat and I was hoping to be able to research and understand it before I get into the oven.
Mainly looking for schematics of the starter/relay/lift pump/battery(master)switch/voltage regulator relationship
DREDnot
627
Avondale , AZ
spent about an hour today before the heat got to me. Tracing some wiring.
It has a 60 amp generator fitted with built in regulator so that explains the missing regulator from the fire wall.
The battery positive wire goes directly to the starter solenoid. A wire from the BATT stud goes up to the start relay box and another from the relay back down to the start lug of the solenoid. I dont see where the rest of the truck gets power from though.
I got the battery switch accessible and saw some wiring issues before giving in to the elements
Not sure what these two circuit breakers are for...
DREDnot
627
Avondale , AZ
We had it transported by our go-to guy.
We are just at the "get it running' stage right now.
Topping fluids, Trying to get power to crank and cleaning the fuel system
GM-M1008
9
Weatherly, PA
I am also looking for the wiring diagram for this series truck. Only thing I have come up with is the gasser wiring diagram in TM 9-2320-211-20-2-2
Al Capone
54
Pearl river la
I have one of these trucks . I don’t have wiring diagram . Do you have the switch / lever in dash that when in the on position it covers up the fuel shutoff pull handle ? This turns on the main power to the truck which turns on lift pump in tank . I would have to check and see if start push button is powered thru there also . I just had to
Remove my starter and clean contacts in solenoid. I have found a aftermarket solenoid on eBay by the way if needed . They don’t know it fits this starter but it does. I just had to change out the air valve on transfer case . It was leaking air real bad . Found nos one for $93 . Also changed the air valves on side transmission but it was not bad . Good luck with the brakes . I had to change out ever metal line . And Almosr every other brake part
DREDnot
627
Avondale , AZ
the wiring to the battery switch.
These were the wires going to the battery switch.
According to a list if military "M-series truck circuit numbers" i found on the innerwebs...
#11 shows as "ignition"
#486 shows as "Manifold heater main engine"
#85 shows as "Low air pressure indicator light"
#24 shows as "light switch to blackout tail lamps"
#484 shows as "Turn indicator main blackout"
#87 shows as "spotlight circuit for trucks and wreckers"
#106 shows as "Gyro Cont to motor stab"
#38 shows as "Dome lamp circuit incl breaker and switch"
GM-M1008
9
Weatherly, PA
I’m trying to figure out the wiring for my battery switch. Can you tell on your which wires are in which spot on the battery switch? The switch will be labeled a,b,c and D. My truck is an a1 Mack so might be a little different but hopefully it’s the same as yours 🤞🏻 I do know I have two #11s that are hot.
DREDnot
627
Avondale , AZ
The letters have deteriorated to where I cant positively ID which is which.
Plus the one wire that makes sense, #11 ignition, that has ribs on the connector, was not plugged into either of the two ribbed receptacles.
So i am skeptical as to the correctness of how they were hooked up.
I still havent found any wiring diagrams for this truck in this configuration
DREDnot
627
Avondale , AZ
Here the trashed connector in the foreground was labeled 87/106/38. The dirty one to the left was labeled 486/85. Notice the position of the two ribbed receptacles.
Here is that wire 486/85 in the foreground and on the left is the frayed #11(ignition?) wire with a ribbed connector that is NOT in a ribbed receptacle which is concerning to me
GM-M1008
9
Weatherly, PA
Ok here is what I found out with mine today. You have 2 number 11s going to the switch. The ribs don’t match up on mine ether. One goes in d that feeds b and one goes in A and feeds C.Then you should have a wire 85/488, 85 is the air warning and I’m guessing 488 is the starter relay because with only that wire plugged in the air buzzer works and truck cranks. So I have the plugged into B. My fourth wire is marked 108/96/598/4 and I’m not sure what they feed yet but I have that plugged into A.
DREDnot
627
Avondale , AZ
Good info. Thanks!
Where do the two #11s get power from? Do they terminate somewhere or do they go to a wrapped spice in the harness somewhere?
I have a significant short (thats melting my negative post) somewhere i need to find before I can hook up the batteries even.
Al Capone
54
Pearl river la
Good info. Thanks!
are your sure you have battery’s hooked up correct . Disconnect the slave / jumpstart cables for now .
DREDnot
627
Avondale , AZ
The batteries are hooked up properly. I will disconnect the slave receptacle though before proceeding.
We installed a new cable from the positive stud to the starter. A new cable between the batteries. The negative cable to frame was in good shape.
Four new clamps.
this is how the starter was hooked up. I took the pic BEFORE i had finished tightening the nut. Red taped wire in big stud goes to starter relay. the far wire comes from the starter relay. the foreground black wire goes to negative/ground stud on end of starter
Al Capone
54
Pearl river la
Looking at your batteries mine has a smaller + wire hooked at the + 24 volt terminal . I would have to track where it goes . Maybe the generator ? Have you been able to spin the truck over with starter or no because of the positive grounding to frame ? I just had my starter apart to clean the contacts inside . Another one had on bench the contractor on top had all fell apart . Maybe this issue could be where yours is ground out ? Just a thought . I did find solenoid off eBay if Need I can tell you part number.
GM-M1008
9
Weatherly, PA
My m54 also has a smaller wire on the 24 volt terminal, I should be by it tomorrow and I’ll check where it goes. I know mine won’t start with out that wire.
DREDnot
627
Avondale , AZ
Have you tested the starter out of the truck ? Just curious
No.
We had the batteries hooked up briefly on day one and we didnt find any signs of power to the truck.
Flipped the battery switch to on and no signs of life. No gauges, no fuel pump, no lights, no air buzzer. nothing. No clicks or sizzles. no burning smells, nothing.
Tried flipping a few mystery switches as well. Nothing. I wasnt there when one of my cohorts hooked up the battery again and melted the negative post.
I have since removed the "starter switch" that was just dangling...
And removed the battery master switch to find this mess...
So thats where i stopped to try and figure out what goes where and without a proper wiring diagram the wire tag decoder doesnt make sense other that one #11 and the two #44 at the "start switch".
The two medium sized leads at the starter coming from the starter relay make sense. But i havent been able to try to trace where the relay activation wire comes from behind the dash yet.
Ive only been able to work on this thing for about 30 minutes at a time around midday before the 110+ heat gets to me.
Yesterday i did manage to remove the lift pump assembly to bench test it.
The pump itself does motor but I need to clean the connections of corrosion and fix where someone molested the motor connection and left the ground strap off. Then replace the hose and see if it pumps fuel.
