Deployable Pavement Repair System Help
gt3535
san antonio tx
Hello all,
I'm looking for any manuals for an Air Force trailer-mounted runway repair system. Basically, a cement batch plant. I cannot find any information online. The manufacturer doesn't have the manuals any longer. I had a friend in the Air Force look up the data plate info, and he could not find anything. Here's the specs. Thank you for any info or direction!
Manufacturer: Entwistle Company- Hudson, Massachusetts
MIL-Spec No. RRR-91-001
NSN 3895014326487
Contract No. f03635-93-C-0031
Date of manufacture: 10/98
Cage 20722
fuzzytoaster
3,687
Fort Worth, Texas
That looks like GSA in SA. Knowing Entwistle, they toss out all the documentation when the equipment is no longer supported by them. They did the same thing to the MHE-270 forklift they produced for the military before they were out of service. That being said, you are likely on your own. It's a specialty piece and civilian at that so it likely doesn't have a TO/TM to support it, just the OEM's documentation. :(
I did some digging and the internet is very sparce for info on your machine. This is literally it.
SPECIAL FEATURESDEPLOYABLE PAVEMENT REPAIR SYSTEM;DUAL AXLE TRAILER W/ON-BOARD MIXING BINS AND CONVEYOR BELT;CAPABLE OF TRANSP.,MIXING AND METERING CONCRETE TO REPAIR RUNWAY CRATERS,SPALLS,RANGING FROM 0.01 TO 8 CUBIC YDS;35,000 LBS.;12 V DC ELEC. AND HYD POWER;WATER HEATER USES DIESEL FUEL;DIESEL CUMMINS 4BTA3.9 ENG.;STORAGE BINS;SPALL REPAIR SYS.;MEAS.452 INCHES L, 96 INCHES 2, AND 126 INCHES H.
